[OpenLayers-Users] OL 2.13 debian 8 geoserver 2.8 - problem with proxy.cgi
pablo zader
pzader at gmail.com
Wed Oct 7 19:00:30 PDT 2015
Hi list
I want to comment: I have understood that using a proxy is insecure because
anyone could navigate through it, doing harmful things! That opinion of
this community there is to it?
I found solutions to cross-domain AJAX calls are:
1 - use a proxy server (not recommended)
2 - use a proxy on the client (as does GeoExplorer, but every client should
have it implemented)
3 - in geoserver enable JSONP (this option seems the best)
I would like to know your opinions about it
Cheers
2015-10-07 6:22 GMT-03:00 Giuseppe Naponiello <beppenapo at gmail.com>:
> Sorry sorry sorry, apache cgi module was not enabled
> Issue resolved!
> 2015-10-07 10:28 GMT+02:00 Giuseppe Naponiello <beppenapo at gmail.com>:
>> ...I forget an important information, in firebug network tab the query
>> string parameters sounds correct, so if I point my browser on this string,
>> I get the correct json array.
>> 2015-10-07 10:00 GMT+02:00 Giuseppe Naponiello <beppenapo at gmail.com>:
>>> Hi all,
>>> I can't undarstand the problem:
>>> server with debian 8, tomcat 8, geoserver 2.8, OpenLayers 2.13.
>>> Apache run over https protocol, all proxy modules are enabled.
>>> WMSGetFeatureInfo:
>>> "info = new OpenLayers.Control.WMSGetFeatureInfo({
>>> url: 'http://localhost:8080/geoserver/raptor/wms',
>>> title: 'Informazioni sui livelli interrogati',
>>> layers: [siti, vincoli, progetti, interventi, ind_neg],
>>> queryVisible: true,
>>> infoFormat:'application/json',
>>> format: new OpenLayers.Format.JSON,
>>> vendorParams: {buffer: 10},
>>> eventListeners: {
>>> getfeatureinfo: function(event) {
>>> var data = event.text;
>>> console.log(data);
>>> map.addControl(info);
>>> info.activate();"
>>> ...but when I click on map I read this error in firebug:
>>> "Uncaught SyntaxError: Unexpected token #"
>>> If I go on localhost/cgi-bin/proxy.cgi, I do not have the expected
>>> result but:
>>> "#!/usr/bin/env python
>>> """This is a blind proxy that we use to get around browser
>>> restrictions that prevent the Javascript from loading pages not on the
>>> same server as the Javascript. This has several problems: it's less
>>> efficient, it might break some sites, and it's a security risk because
>>> people can use this proxy to browse the web and possibly do bad stuff
>>> with it. It only loads pages via http and https, but it can load any
>>> content type. It supports GET and POST requests."""
>>> import urllib2
>>> import cgi
>>> import sys, os
>>> # Designed to prevent Open Proxy type stuff.
>>> I probably forgot to install some library?
>>> How to fix this annoying problem?!
>>> Thanx
>>> -beppe-
>>> *Giuseppe Naponiello*
>>> *A**rc-**T**eam srl*
>>> piazza Navarrino, 13 - 38023Cles (TN)
>>> C.F. e P. IVA IT-01941600221
>>> cell. +393476846599
>>> mail: beppenapo at arc-team.com
>>> pec: arc-team at pec.it
>>> www.arc-team.com
>>> http://arc-team-open-research.blogspot.it/
>> cell. +393476846599
>> www.arc-team.com
> cell. +393476846599
> www.arc-team.com
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
*Pablo J. Zader*
*Lic. en Cs. de la Computación*
*pablo.zader at gmail.com <pablo.zader at gmail.com>*
*"Los Grandes Hombres hablan sobre ideas... Los Hombres Promedio hablan
sobre cosas... Los Hombres Pequeños hablan.. de otros Hombres.*
*del libro Matemática estas ahi? A. Paenza "*
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20151007/e0ae0619/attachment.html>
