[OpenLayers-Users] vector layer reprojection
Giuseppe Falcone
falcone.giuseppe at gmail.com
Wed Aug 24 05:51:56 PDT 2016
thanks for the response.
The situation is a bit different.
The feature are already loaded into layer and visible onto map. Now I have
a combo control by which I modified SR onto map.
With this operation raster layers are reprojected correctly.
For raster layers what I have to do? I have to remove and re-add features
on vector layer?
Thanks.
Giuseppe
2016-08-24 14:13 GMT+02:00 pra shant <prashu84k at gmail.com>:
> Hi,
> Try to transform all features using below code and then add features to
> vector layer.
> Initialize and add all layers while map loading and then perform
> transformation operation on every feature.
> geometry.transform(4326,3857);
> feature.setGeometry(geometry);
> vectorlayer.add(feature);
> Regards,
> Prashant Kirpan
> On Wed, Aug 24, 2016 at 4:19 PM, Giuseppe Falcone <
> falcone.giuseppe at gmail.com> wrote:
>> Hi all,
>> I have a problem with vector layer reprojection.
>> I have implemented a map viewer where is possible to change reference
>> system.
>> If I load vector layer after that I have changed SR, this is correctly
>> loaded. If i load vector layer and then I change SR, the raster layers are
>> reprojected correctly, but the vector layer disappear.
>> Any idea?
>> Thanks a lot.
>> Giuseppe
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20160824/9ee013b4/attachment.html>
