[OpenLayers-Users] OL 4.2 with TypeScript:How to extend index.d.ts?
Ignacio Talavera ignacio.talavera at gmail.com
Wed Aug 9 10:02:33 PDT 2017
Thanks, Finally I found a workaround instead of invoking *getFullTileRange *
method.
strategy: ol.loadingstrategy.tile(tileGrid),
url: function(extent, resolution) {
        var tileCoord = tileGrid.getTileCoordForCoordAndResolution(
ol.extent.getCenter(extent), resolution);
        var z = tileCoord[0];
        var x = tileCoord[1];
        var y = tileCoord[2];
        *//var range = tileGrid.getFullTileRange(z);*
*        y = **Math.pow(2, z) + y;**//range.getHeight() + tileCoord[2];*
        return '/geoserver/gwc/service/tms/1.0.0/' +layer
+'@EPSG%3A'+projection_epsg_no+'@geojson/'+z+'/'+ x+'/'+ y+'.geojson';
I
On Tue, Aug 8, 2017 at 4:27 AM, Olivier Guyot <olivier.guyot at camptocamp.com>
wrote:
> You could try using *tileGrid.getTileRangeForExtentAndResolution(extent,
> resolution)* instead, although this is not part of the public API either.
> Whichever way you chose, it doesn't make sense that your code gives you an
> execution error on *tileGrid.getFullTileRange* but not on
> *tileGrid.getTileCoordForCoordAndResolut**ion*, as a ol.tilegrid.TileGrid
> should have both functions on its prototype. Are you sure this is the error
> you're getting?
> *camptocamp*
> INNOVATIVE SOLUTIONS
> BY OPEN SOURCE EXPERTS
> *Olivier Guyot*
> Geospatial Developer
> +33 4 58 48 20 28 <+33%204%2058%2048%2020%2028>
> On Mon, Aug 7, 2017 at 7:41 PM, Ignacio Talavera <
> ignacio.talavera at gmail.com> wrote:
>> Thanks! perhaps I'm trying the wrong way. I',m using vector-tile from
>> geoserver and I get the same problem mentioned here
>> <https://stackoverflow.com/a/34850171> so I try to use ol.source.Vector
>> with ol.loadingstrategy.tile as loading strategy as follows.
>> *        var range = tileGrid.getFullTileRange(z);*
>> *        y = range.getHeight() + tileCoord[2];// I need the range to
>> transofrm 'Y' coordinate to fit  in geoserver tile range.*
>> Is there any workaround?
>> On Mon, Aug 7, 2017 at 12:46 PM, Olivier Guyot <
>> olivier.guyot at camptocamp.com> wrote:
>>> Hi,
>>> This function is not part of the public API, hence the fact it is not
>>> exposed in Typescript definitions. You could still use it without errors by
>>> casting the ol.tilegrid.Tilegrid object to `any`, like so:
>>> *(tilegridObj as any).getFullTileRange()*
>>> Although that is obviously not the recommended way to go.
>>> As for the execution error, Typescript would have nothing to do with
>>> that so there's probably a problem with how the tilegrid object is created.
>>> *camptocamp*
>>> *Olivier Guyot*
>>> On Mon, Aug 7, 2017 at 4:49 PM, Ignacio Talavera <
>>>> I'm using Openlayers v4.2.0 with typescript so I installed the
>>>> typesDefinition with npm install --save @types/openlayers
>>>> I need to execute the method *getFullTileRange()* from
>>>> ol.tilegrid.TileGrid type  but is not defined in the type definition from
>>>> @types/openlayers (index.d.ts).
>>>> First I get a compilation error because getFullTileRange method is not
>>>> declared in index.d.ts. I try to modify index.d.ts adding this method
>>>> (inside my IDE to skip compilation errors) but running my app I  get this
>>>> exection error
>>>> *TypeError*: *tileGrid.getFullTileRange is not a function*.
>>>> How can I extend index.d.ts to execute that function?
>>>> Thanks!
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/openlayers-users
>> Ing Ignacio Talavera
>> Tel: (+598) 99 993 382
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20170809/b4039916/attachment.html>
