[OpenLayers-Users] blurry tiles
Andreas Hocevar
andreas.hocevar at gmail.com
Mon May 4 13:13:32 PDT 2020
By default, OpenLayers applies up- and downscaling to the tiles. To avoid
upscaling, configure the source with
zDirection: -1
Andreas.
On Mon, May 4, 2020 at 8:47 PM Toni Hernandez Valles <toni.hernandez at udg.edu>
wrote:
> Helo everyone,
> I am using a vector tile from mapbox and I am getting bluring tiles
> with no apparent reason. Not for me, at least
> I have checked tiles directly to mapbox and the quality is perfect,
> but, when using tiles with OpenLayers the map quality gets lower.
> In this link (https://mapscloud.udg.edu/blurry_tiles.png) you can see
> the quality of the map image (on the left) and the quality of a single
> tile. Check the costline and the name "Roses" to see the difference.
> I have tried both tile sizes (256 and 512) with the same result.
> This is the code for the layer for size 256.
> var mapbox = new TileLayer({
> source: new SourceXYZ({
> url: '
> https://api.mapbox.com/styles/v1/mapesbasesigte/ck9olcn8017xc1it6mhv6myje/tiles/256/{z}/{x}/{y}?access_token=mytoken
> And the code for the map.
> map = new Map({
> layers: [ mapbox ],
> target: 'map',
> view: new View({
> center: [0, 0],
> zoom: 2,
> projection: 'EPSG:3857',
> controls: defaultControls({attribution:
> false}).extend([attribution]),
> Am I doing something wrong?
> Thanks you!!!
> Users mailing list
> Users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20200504/8dd489c7/attachment.html>
