[OpenLayers-Users] COG and basemap
Marc Jansen
jansen at terrestris.de
Fri May 27 03:47:35 PDT 2022
Hi Jakob,
nice that you have it working now. WRT the reprojection, yes, that is
not possible right now, but:
https://github.com/openlayers/openlayers/pull/13654
Best
Marc
Am 27.05.22 um 12:32 schrieb Jakob Miksch:
> Hi Marc,
> If I leave out extent, the COG is displayed on a wrong place. (Should
> be Buonos Aires, but is placed in France).
> Increasing the extent shows an visual effect, but still causes the OSM
> map to be placed on the wrong place.
> Meanwhile, I made it work inspired by
> https://stackoverflow.com/a/70116989 and
> https://codesandbox.io/s/cog-forked-tmswq?file=/main.js
> It seems I needed to define the projection using Proj4js and not with
> OL directly.
> One learning is that apparently COGs cannot be reprojected by OL.
> (Please correct me if I am wrong)
> Initially I tried to create something similar as here:
> https://cholmes.github.io/cog-map/
> This app displays COGs in any CRS on WebMercator, BUT it actually uses
> the backend service https://tiles.rdnt.io/ for proxying and reprojection.
> Best,
> Jakob
> importGeoTIFFfrom'ol/source/GeoTIFF.js';
> importMapfrom'ol/Map.js';
> importWebGLTileLayerfrom'ol/layer/WebGLTile.js';
> importViewfrom'ol/View.js';
> importTileLayerfrom'ol/layer/Tile';
> importOSMfrom'ol/source/OSM';
> importproj4from"proj4";
> import{ register} from"ol/proj/proj4";
> import{ fromLonLat} from"ol/proj";
> constepsgCode= "EPSG:32721";
> proj4.defs(epsgCode,"+proj=utm +zone=21 +south +datum=WGS84 +units=m
> +no_defs");
> register(proj4);
> constcogSource= newGeoTIFF({
> sources:[
> url:'https://sentinel-cogs.s3.us-west-2.amazonaws.com/sentinel-s2-l2a-cogs/21/H/UB/2021/9/S2B_21HUB_20210915_0_L2A/TCI.tif',
> constcogLayer= newWebGLTileLayer({
> source:cogSource,
> newMap({
> target:'map',
> layers:[
> newTileLayer({
> source:newOSM()
> cogLayer
> view:newView({
> projection:epsgCode,
> center:fromLonLat([-58.205,-34.833], epsgCode),
> zoom:10,
> Am 27.05.22 um 10:35 schrieb Marc Jansen:
>> Hi Jakob,
>> what happens if you change the extent of the view (leave it out,
>> configure it to sth. bigger that the extent of the source)?
>> Just a wild guess.
>> Best
>> Marc
>> Am 27.05.22 um 10:18 schrieb Jakob Miksch:
>>> Dear list,
>>> I am trying to display COGs in OpenLayers. This works well for
>>> single images. However, I would like to add more more layers like a
>>> basemap. But then the view is blocked to the extent of the COG. See
>>> my example below.
>>> Is there a way to overlay a COG on a basemap and still be able to
>>> zoom and pan wherever I want and not being restricted by the extent
>>> of the COG?
>>> best regards,
>>> Jakob
>>> importProjectionfrom'ol/proj/Projection.js';
>>> import{getCenter} from'ol/extent.js';
>>> constprojection= newProjection({
>>> code:'EPSG:32721',
>>> units:'m',
>>> // metadata from
>>> https://s3.us-west-2.amazonaws.com/sentinel-cogs/sentinel-s2-l2a-cogs/21/H/UB/2021/9/S2B_21HUB_20210915_0_L2A/S2B_21HUB_20210915_0_L2A.json
>>> constsourceExtent= [300000, 6090260, 409760, 6200020];
>>> sources:[
>>> source:cogSource,
>>> newMap({
>>> target:'map',
>>> layers:[
>>> newTileLayer({
>>> source:newOSM()
>>> cogLayer
>>> view:newView({
>>> projection:projection,
>>> center:getCenter(sourceExtent),
>>> extent:sourceExtent,
>>> zoom:1,
>>> Jakob Miksch
>>> Geoinformatiker
>>> meggsimum - Büro für Geoinformatik
>>> Christian Mayer
>>> Schillerstr. 2a | 67112 Mutterstadt
>>> info at meggsimum.de | www.meggsimum.de
>>> T 06231 - 6298988 |
>>> Users mailing list
>>> Users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/openlayers-users
>> Marc Jansen
>> — Geschäftsführer —
>> terrestris GmbH & Co. KG
>> Kölnstraße 99
>> 53111 Bonn
>> Tel: +49 (0)228 / 96 28 99 -53
>> Fax: +49 (0)228 / 96 28 99 -57
>> Email: jansen at terrestris.de
>> Web: https://www.terrestris.de
>> Amtsgericht Bonn, HRA 6835
>> Komplementärin: terrestris Verwaltungsgesellschaft mbH
>> vertreten durch: Torsten Brassat, Marc Jansen
>> Informationen über Ihre gespeicherten Daten finden Sie auf unserer Homepage unter folgendem Link: https://www.terrestris.de/datenschutzerklaerung/
>> Users mailing list
> Jakob Miksch
> Geoinformatiker
> Christian Mayer
> T 06231 - 6298988 |
> Users mailing list
Marc Jansen
— Geschäftsführer —
Kölnstraße 99
53111 Bonn
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20220527/165416f9/attachment-0001.htm>
