[osgeo4w-dev] Installer,
Express Install does not ask for instalation folder.
Ivan Lucena
ivan.lucena at pmldnet.com
Tue Dec 30 01:09:26 EST 2008
Hi Frank,
>> The "Express" options install everything on C:/OSGeo4w without asking
>> the user where to install.
> I think this is intentional. That is, we try to minimize the number
> of questions when doing an express install.
The problem is that some system administrators like to keep a reserved
driver C: just for Windows and install other application on secondary
drivers.
My humble suggestion would be to give the user a folder name entry
filled with "C:\OSGeo4w" as default. Some people just hit 'next'
carelessly anyway. Not a big deal.
> OSGeo4W was based on the stable version of GDAL (1.5) at the point it was
> launched (early 2008). Because lots of packages are built against GDAL
> we can't easily migrate the default/public version of GDAL to 1.6, though
> 1.6 is available as a special install which you need to type "gdal16" at
> the commandline to use.
OK. So I can install 'advanced' and use 'gdal16' to switch versions. I
didn't know that. I am going to test the georaster driver then.
> The intention is that at some point (perhaps soon) we would start
> building a new generation of OSGeo4W (perhaps OSGeo4W Ver2) using
> the stable versions of core libraries that are available.
I believe that it is a very valuable effort to put all those pieces
together and the concern with non-experts-users is quite lovable.
For myself I usually compile everything that I use but I am writing
those comments not as a critic but to share the reaction that I am
getting from people to whom I am 'prescribing' OSgeo4W for.
By the way, I believe that the icon desktop shortcut to 'openev.bat' and
the menu entry is missing from the OpenEV installation.
The best regards,
Ivan
More information about the osgeo4w-dev
