[osgeo4w-dev] o4w-apt: an apt-get like utility for OSGeo4W
Matt Wilkie
matt.wilkie at gov.yk.ca
Fri Jul 4 15:47:02 EDT 2008
Here is a batch file to test a "from scratch" install (requires an
existing python.exe). It's runs successfully with r37 of o4w-apt.py
(which I'm about to rename simply "apt.py")
@echo off
echo.
echo. Install OSGeo4W from scratch
echo.
echo. THIS WILL REMOVE EXISTING C:\OSGEO_4W!
echo.
if not [%1]==[yes] goto :Usage
:SetEnv
setlocal
set pythonpath=
set osgeo4w_root=C:\OSGeo4W
set osgeo4w_root_msys=%osgeo4w_root%
set o4w-apt=c:\OSGeo4W.extras\bin\o4w-apt.py
set python=d:\PortablePython1.0\python.exe
echo %python% %o4w-apt% %%* > apt.bat
:CleanSlate
if exist %osgeo4w_root% rd /s/q %osgeo4w_root%
md %osgeo4w_root%
:DoIt
call apt setup
call apt update
call apt install gdal
:Test
%osgeo4w_root%\bin\gdalinfo --version
goto :eof
:Usage
echo. if you don't say "%0 yes" I won't do it.
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
Frank Warmerdam wrote:
> Matt Wilkie wrote:
>>> - I did not have a setup.ini in c:/osgeo4w/etc/setup, so I ended up
>>> copying
>>> it there manually from my cache directory.
>> Ahhh, that is because one needs to run 'o4w-apt setup' first on a new
>> machine. I neglected to document that.
> Matt,
> Ah!
>>> - The openev postinstall target did not work on an upgrade because the
>>> OSGEO4W_ROOT and OSGEO4W_ROOT_MSYS environment variables were not
>>> defined.
>> I'm getting that error too, even when the env is set:
>> C:\Osgeo4W> set osg
>> OSGEO4W_ROOT=C:\Osgeo4W
> You also need to set OSGEO4W_ROOT_MSYS which should be an MSYS
> compatible path. Usually something like "/c/OSGeo4W" I think.
>>> - The setup command does not run \bin\osgeo4w-setup.exe
>> What would the purpose of that be? What will that do that is not
>> covered by o4w-apt?
> Sorry, I misunderstood the role of the setup command. I assumed it
> was a way of running the gui. Disregard my comment.
>> (We've got to find a different name. Mixing numbers and letters
>> mid-word like that is just too difficult to type!)
> I'd be in favor of just calling your program "apt" instead of o4w-apt -
> I have the same problem with that being very ackward to type.
>>> I'm interested in getting this packaged up (including a "covering"
>>> bat file since the osgeo4w shell does not know how to run .py files).
>> I've got a batch file which does this for all .py in osgeo/bin[1], see
>> :MakeBats function:
>> cd /d %OSGEO4W_ROOT%\bin
>> for %%g in (*.py) do (
>> if not exist %%~ng.bat echo @python "%%OSGEO4W_ROOT%%\bin\%%g"
>> %%* > %%~ng.bat
>> goto :EOF
>> [1]
>> http://code.google.com/p/maphew/source/browse/trunk/gis/o4w_extras/install-o4w-extras.bat
>> I'd love to have this included within osgeo4w. I'm sure more skilled
>> eyes than mine checking it out would be of great benefit.
> This could be a useful addition to the python package, making it easy for
> other packages to create all the stub .bat files as part of their post
> install
> step. Perhaps you could file a ticket with the details, and I could update
> the python package to include this, and the gdal-python package to use
> this.
> PS. While I agree with Jeff that this apt utility will not be the primary
> interface for new users, I think it is very handy for the not insignificant
> group of us who are keen on commandline mechanisms. I think the hardest
> challenge is ensuring it integrates smoothly with other installation
> mechanisms
> (like handling of postinstall steps, use of a common cache directory).
> Best regards,
More information about the osgeo4w-dev
