[osgeo4w-dev] xmmklink not found
Frank Warmerdam
warmerdam at pobox.com
Sat Jun 28 18:55:50 EDT 2008
andrea antonello wrote:
> I am trying to create links to the executable. The problem is that
> nothing was created on install.
> When I try to execute it manually, I get an error about the exectable
> xmmklink not beeing found.
> Where is it supposed to be?
Andrea,
xxmklink.exe should be in %OGSEO4W_HOME%\bin and is part of the msvcrt
package. If you have an old version of msvcrt you may need to upgrade to
msvcrt-1.0.0-6.
Also check your spelling, I see you mentioned "xmmklink" above.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
More information about the osgeo4w-dev
