[osgeo4w-dev] setup in svn and improved a bit
Jason Fournier
jfournier at dmsolutions.ca
Sat Mar 1 10:20:31 EST 2008
Frank,
It worked. Here's the output:
C:\OSGeo4W>shpproj
shpproj shp_file new_shp ( -i=in_proj_file | -i="in_params" | -i=geographic
-o=out_info_file | -o="out_params" | -o=geographic )
C:\OSGeo4W>
Best regards,
Jay
-----Original Message-----
[mailto:osgeo4w-dev-bounces at lists.osgeo.org] On Behalf Of Frank Warmerdam
Sent: Friday, February 29, 2008 9:39 PM
To: Norman Vine
Cc: osgeo4w-dev at lists.osgeo.org
Subject: Re: [osgeo4w-dev] setup in svn and improved a bit
Norman Vine wrote:
> The post XP sp1 Msoft system dll thing is a pain
> For vc8 there is vcredist.exe not sure about vc9
http://blogs.msdn.com/nikolad/archive/2007/04/02/workaround-for-using-vs2005
> -sp1-version-of-vcredist-exe-within-a-boostrapper-setup-exe.aspx
Norman,
I read this over, but didn't really grok it all that well.
However, I did find that by adding the manifest for the vc runtime
dlls into the msvcrt-1.0.0 package I was able to correct the problem on
my win32 laptop which also exhibited the problem that Jay was running
into.
Jay - if you just step through setup without installing any new packages it
ought to re-install msvcrt including the manifest and correct the problem.
Let me know if you discover otherwise.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | President OSGeo, http://osgeo.org
osgeo4w-dev mailing list
http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
More information about the osgeo4w-dev
