[osgeo4w-dev] Express Install Implemented
    Frank Warmerdam
    warmerdam at pobox.com
    Thu Mar 20 12:24:43 EDT 2008
Matt Wilkie wrote:
> - As there is only one download site, it should be selected by default
> (and even when there are choices download.osgeo.org should be selected
> by default).
Matt,
I have confirmed this and reopened:
   http://trac.osgeo.org/osgeo/ticket/223
> - Pressing the back button after having progressed one or two [nexts]
> show screens which the user has never seen. This will be confusing to
> people who've never tried the Advanced install.
This is correct.  Could you file a ticket on this, noting any dialogs
from which the "back" button misbehaves in this way?  I need some extra
logic in the OnBack() methods to handle express mode differently.
> - would be nice if the package selection screen had more info than just
> the name on the packages
I think this needs to be discussed more broadly, but luckily it is
easy to add/modify this text in the res.rc file.  I will stress that the
more text we put per-package, the less room we have for more packages on
the express install screen.
> After install, I get this popup error when typing gdalinfo (or any other
> utility) in the OSGeo4W shell:
> gdalinfo.exe - Unable To Locate Component
I have determined that the way I am doing the express install now
is *not* installing dependent packages properly.  I hadn't noticed
this in testing since I was not installing from scratch.  Could you
also file a ticket on this?
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
More information about the osgeo4w-dev
