[osgeo4w-dev] gdal-python packages & gdal_merge
Fri Oct 10 09:29:15 EDT 2008
fabienne picot wrote:
> That's ok: I have uninstall the gdal-sde and gdal-ecw plugin packages
> Now when I type "gdalinfo",I get this:
> Usage: gdalinfo [--help-general] [-mm] [-stats] [-hist] [-nogcp] [-nomd]
> [-noct] [-checksum] [-mdd domain]* datasetname
> So what do I do now?
Fabienne,
Try the gdal_merge script again, and see if it works better now.
At the OSGeo4W shell just try:
gdal_merge
Best regards,
More information about the osgeo4w-dev mailing list
