[osgeo4w-dev] gdal_merge_mosaïc TIF
Matt Wilkie matt.wilkie at gov.yk.ca
Tue Oct 14 12:13:47 EDT 2008
Also see http://trac.osgeo.org/gdal/wiki/UserDocs/GdalMerge which has a
batch file for doing the same.
cheers,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
Matt Wilkie wrote:
> Bonjour Fabienne,
> The error "line is too long" is from CMD not gdal_merge. There are
> simply too many characters in the variable %liste%. A work around is to
> read the input files from a text file. E.g.
>   cd /d c:\image
>   dir /s/b *.tif > input-images.txt
>   set opts= -co bigtiff=yes -co tfw=yes
>   gdal_merge %opts% -o results.tif --optfile input-images.txt
> Salut!
> matt wilkie
> fabienne picot wrote:
>> Hi
>> I'd like to assemble images *".TIF" which total size is 8Go, to have 1
>> image which size would be the smallest possible (with the best quality
>> of course!).
>> - I add "@cmd.exe /V:ON" at the end of OSGEO4W.BAT to activate
>> additional functionalities to create a list of files in the form of
>> variables.
>> - Then:
>>       cd /d c:\Image
>>     * set liste= [ ]
>>     * for %c in (*.tif) do set liste=%c !liste!
>>     * gdal_merge -of GTiff -co "TFW=yes" -co "BIGTIFF=yes"
>>       "c:\Image\Test.tif" %liste%
>> But the prompt answers: "THE ENTERED LINE IS TOO LONG".
>> What it doesn't like?
>> Is it the correct method to assemble and reduce image'size?
>> Best regards
>> Téléphonez gratuitement à tous vos proches avec Windows Live
>> Messenger  !  Téléchargez-le maintenant !
>> <http://www.windowslive.fr/messenger/1.asp>
>> osgeo4w-dev mailing list
>> osgeo4w-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
More information about the osgeo4w-dev mailing list
