[osgeo4w-dev] EPPL7 problem still exists
Yewondwossen Assefa
yassefa at dmsolutions.ca
Wed Sep 17 10:37:29 EDT 2008
The link is correct.
When you do the installation, use the "Advanced Install" setting and
in the "libs" section, you need to download the gdal-ecw package. That
should create the plugins directory and put the gdal_ECW_JP2ECW.dll in it.
Best Regards,
Derek Bain wrote:
> Hi
> Thanks for the reply (sorry if I got your name wrong in previous post)
> I tried gdalinfo --formats and I do not have ECW/JPEG2000 support. I
> checked for the gdalplugins folder and the folder does not exist. To be
> on the safe side, I searched for gdal_ECW_JP2ECW.dll in any folder under
> the OSGeo4W installation and that does not exist either.
> I installed my version of OSGeo4W using the link supplied by Frank
> Warmerdam (http://trac.osgeo.org/osgeo4w/) and downloaded and installed
> the ERMapper SDK dll's into my System32 folder as recommended in the
> notes (http://trac.osgeo.org/osgeo4w/wiki/pkg-gdal-ecw).
> Is the download link above correct? or is there something else I should
> install.
> thanks
> Derek
> osgeo4w-dev mailing list
> osgeo4w-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
More information about the osgeo4w-dev
