[osgeo4w-dev] genini fix
Jürgen E. Fischer
jef at norbit.de
Tue Aug 4 14:15:01 EDT 2009
Hi Frank,
On Mon, 03. Aug 2009 at 10:35:04 -0400, Frank Warmerdam wrote:
> I find genini very slow, and at some point I'd like to rewrite it in some
> more efficient form. I'm not really sure what part is the slow part. But
> Currently the genini step often times out on me if anything else is happening
> on the machine at the same time.
I added some comments.
The problem is that the md5sums of the packages are recalculated on each run.
That's taking >90% of the time.
#100 now has a patch that saves the md5sums along with timestamp and filesize
to a separate file. So on re-runs the md5sum are reused unless the timestamp
or the file size changed.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
More information about the osgeo4w-dev
