[osgeo4w-dev] Re: [osgeo4w] #101: setup.exe doesn't understand .bz2 archives created by 7zip (and cygwin, gnuwin32?)
OSGeo4W trac_osgeo4w at osgeo.org
Fri Aug 7 13:13:37 EDT 2009
gnuwin32?)
Reporter:  maphew  |        Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  defect  |       Status:  new
Priority:  major   |    Component:  Documentation
 Version:          |   Resolution:
Keywords:          |
Comment (by dsampson):
 it might require some clarification... the gnuwin32 project ships two tar
 packages.. gnutar DOES NOT WORK.
 try bsdTAR found here http://gnuwin32.sourceforge.net/packages.html
 http://gnuwin32.sourceforge.net/packages/libarchive.htm is the home page
 for libarchive...
 it allows you to chain actions such as
 tar xvjf
 and
 tar cvjf
 I guess it shipps with bzip2 inside the application where the gnuwin32 tar
 and bzip tools are shipped seprately and the tar program was not compiled
 with bz2.
 Just some clarification.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/101#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev mailing list
