[osgeo4w-dev] Compile Help
Sampson, David
David.Sampson at NRCan-RNCan.gc.ca
Thu Aug 13 15:28:42 EDT 2009
I do have instructions for compiling this package (PAGCgeo.org) with mingw I was just not sure if that would meet the criteria for osgeo4w.
So I shall resort to that.
BTW if OSGEO4W has no compiler then how can you distribute source packages for compiling? Or would the source only be for building other packages?
Sorry for the novice questions. Your responses are appreciated.
Cheers
> -----Original Message-----
> From: osgeo4w-dev-bounces at lists.osgeo.org
> [mailto:osgeo4w-dev-bounces at lists.osgeo.org] On Behalf Of
> Jürgen E. Fischer
> Sent: Thursday, August 13, 2009 15:04
> To: osgeo4w-dev at lists.osgeo.org
> Subject: Re: [osgeo4w-dev] Compile Help
> Hi David,
> On Thu, 13. Aug 2009 at 14:28:54 -0400, Sampson, David wrote:
> > A better question to start off is HOW should we compile programs to
> > distrubte with OSGEO4W..
> > Can we just do it through a stock version of MSYS/MINGW or
> should we
> > compile within OSGEO4W? What about CYGWIN?
> Although I didn't do a survey, I think most of the software
> in OSGeo4W is
> compiled with various versions of Microsoft Visual C++.
> E.g. GDAL, proj4,
> GEOS, python and Qt & QGIS. The last two with Visual C++
> 2008 Express Edition.
> GRASS is compiled with MinGW and the osgeo4w installer with cygwin.
> The build processes on Windows are often more involved that
> simply running configure && make install and differ from
> package to package.
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel.
> +49-4931-918175-20
> Dipl.-Inf. (FH) Rheinstraße 13 Fax.
> +49-4931-918175-50
> Software Engineer D-26506 Norden
> http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und
> Informationssysteme mbH Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> osgeo4w-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
More information about the osgeo4w-dev
