[osgeo4w-dev] [osgeo4w] #106: Once disabled Python plugin
repositories could not be enabled
trac_osgeo4w at osgeo.org
Mon Aug 24 12:27:36 EDT 2009
#106: Once disabled Python plugin repositories could not be enabled
Reporter: zirneklitis | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Component: Package
Version: 1.0 | Keywords: Python plugin manager
There is the possibility in «QGIS Python Plugin Installer» window's tab
«Repositories» to disable added repositories. Once it is done the
repository became inactive and there is no way to enable the repository.
It is impossible to remove the repository as well. There is no such a
problem in the standalone QGIS version (1.0.2) from http://qgis.org/.
QGIS version: 1.0.2-2
OS: Windows XP PRO SP3
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/106>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev
