[osgeo4w-dev] Re: [osgeo4w] #44: Gdal/Proj problems with Grass
	installation
    trac_osgeo4w at osgeo.org
    Wed Feb  4 11:16:42 EST 2009
#44: Gdal/Proj problems with Grass installation
  Reporter:  cnielsen   |       Owner:  osgeo4w-dev at lists.osgeo.org
      Type:  defect     |      Status:  closed
  Priority:  major      |   Milestone:
 Component:  Installer  |     Version:
Resolution:  fixed      |    Keywords:  grass, qgis
Changes (by cnielsen):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Update: the non-test version grass-6.4.0RC3-2 seems to have resolved this
 issue. There were still several packages I had to add manually including:
 curl, expat, hdf, libjpeg, libmysql, netcdf, ogdi, and xerces.
 QGIS seems also to have been fixed, at least for that library. But an
 QtCore4 error came up instead. (QtCore4.dll is installed).
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/44#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev
