[osgeo4w-dev] [osgeo4w] #46: Setup shortcut doesn't work after update
OSGeo4W trac_osgeo4w at osgeo.org
Wed Feb 4 13:44:04 EST 2009
 Reporter:  mwtoews        |       Owner:  osgeo4w-dev at lists.osgeo.org
     Type:  defect         |      Status:  new
 Priority:  major          |   Milestone:
Component:  Documentation  |     Version:
 Keywords:                 |
 After updating setup from version 1.0.3-4 to 1.0.3-6 and restarting the
 computer, the "Setup" shortcut (in Start > OSGeo4W) raises the error
 dialog (attached):
  '''osgeo4w-setup-work.exe'''
  Windows cannot find 'osgeo4w-setup.work.exe'. Make sure you typed the
 name correctly, and then try again. To search for a file, click the Start
 button, and then click Search.
  ['''OK''']
 Inspecting the properties for this shortcut shows that it references
 C:\gnu\OSGeo4W\bin\setup.bat which is a UNIX (not DOS line-ending) file:
 @copy "%OSGEO4W_ROOT%\bin\osgeo4w-setup.exe" "%OSGEO4W_ROOT%\bin\osgeo4w-
 setup-work.exe"
 @start osgeo4w-setup-work.exe %*
 This is likely related to #45.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/46>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev mailing list
