[osgeo4w-dev] Re: [osgeo4w] #47: Start menu is disorganized
OSGeo4W trac_osgeo4w at osgeo.org
Wed Feb 4 22:21:45 EST 2009
  Reporter:  mwtoews      |       Owner:  osgeo4w-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  minor        |   Milestone:
 Component:  Installer    |     Version:
Resolution:               |    Keywords:
Comment (by mwtoews):
 Replying to [comment:2 warmerdam]:
 > but perhaps you could manually remove all the start menu items, and the
 installed OSGeo4W tree and then reinstall to see if the problem occurs
 again?
 I did this, and it did "clean" it up by removing the second QGIS shortcut,
 but I still see the double nesting "OSGeo4W > OSGeo4W > OSGeo4W Shell" as
 shown in the original attachment.
 > I thought we did have an apache install/restart/uninstall at one point,
 but I don't see it on mine.
 In OSGeo4W/bin, I see:
 apache-install.bat    apache-restart.bat    apache-uninstall.bat
 Maybe the Shell PATH should also include OSGeo4W/apache/bin for the other
 Apache related programs from the CMD/msys shells?
 Also, I found the handy task bar control at
 OSGeo4W/apache/bin/ApacheMonitor.exe which I think is a good candidate EXE
 to add to the Start menu.
 Finally, it would make sense to group all Apache related programs into
 it's own group: Start > OSGeo4W > Apache
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/47#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev mailing list
