[osgeo4w-dev] error rgdal library if used from within Grass
plugin (Windows)
Roger Bivand
Roger.Bivand at nhh.no
Mon Feb 9 13:32:32 EST 2009
On Mon, 9 Feb 2009, Agustin Lobo wrote:
> Hi!
> The following error only occurs if the R (2.7.2) session is started
> from a GRASS shell opened through the QGIS GRASS plugin in windows.
> The error does not occur If R is started form its own icon
> or by double click in the .RData object, but then the spgrass6
> package would not find the GRASS environment.
> It also works in linux.
> The involved commands are:
> 1. Start QGIS
> 2. Star GRASS plugin and open mapset
> 3. Open Grass Shell
> 4. Run R and execute require(spgrass6)
>>>>> Loading required package: spgrass6
>>>>> Loading required package: rgdal
>>>>> Error in fun(...) :
>>>>> GDAL Error 1: Can't load requested DLL:
>>>>> C:\OSGeo4W\bin\gdalplugins\gdal_ECW_JP2ECW.dll
>>>>> 126: Não foi possível encontrar o módulo especificado.
Agus:
I've already replied to this question twice already, on R-sig-geo and
statgrass. You are not saying which rgdal Windows binary you are using -
without knowing that, any resolution is hopeless. If you are using my
trial binary on:
http://spatial.nhh.no/R/Devel/rgdal_0.6-6.zip
as mentioned in my message to R-sig-geo:
https://stat.ethz.ch/pipermail/r-sig-geo/2009-January/004860.html
then either version drift, or QGIS not passing on PATH values are
possible. I don't think that this is likely, as it was built against R
2.8.*
There is an underlying question about how to build and distribute the R
contributed packages sp, rgdal and spgrass6 in the OSGeo4W framework.
Bundling R in OSGeo4R doesn't seem to be a good idea, because users will
prefer, I think, to use their own R installation. So probably OSGeo4W
should ship with Windows package binaries for current R (changes every six
months), including a custom built rgdal. I've built this with the
downloadable MS VC++ compiler and build train, and would have to rebuild
for each rgdal release, and in any case when R upgrades.
Roger
>>>>> Error : .onLoad failed in 'loadNamespace' for 'rgdal'
>>>>> Erro: package 'rgdal' could not be loaded
> Any help appreciated.
> Agus
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the osgeo4w-dev
