[osgeo4w-dev] Re: [osgeo4w] #37: grass: wxpython gui issues
OSGeo4W trac_osgeo4w at osgeo.org
Mon Feb 23 05:21:11 EST 2009
  Reporter:  jachym   |       Owner:  osgeo4w-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  major    |   Milestone:
 Component:  Package  |     Version:
Resolution:           |    Keywords:  GRASS
Comment (by marisn):
 Replying to [comment:24 hamish]:
 > Path to the EPSG-codes file: /c/OSGeo4W/share/proj/epsg
 > if you click "browse EPSG codes", you get an error that the file can't
 be found. If you browse for the EPSG file, the path becomes
 `C:/OSGeo4W/share/proj/epsg` and then it all works: ie the nice code table
 browsing, searching, & grabbing.
 Path in Tcl/Tk is taken from env variable: GRASS_PROJSHARE that is set
 during compilation(?). Make it correct on Windows and there will be no
 error messages.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/37#comment:25>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev mailing list
