[osgeo4w-dev] Re: [osgeo4w] #41: gdal16.dll not found
OSGeo4W trac_osgeo4w at osgeo.org
Wed Jan 28 12:42:58 EST 2009
  Reporter:  cnielsen   |       Owner:  osgeo4w-dev at lists.osgeo.org
      Type:  defect     |      Status:  new
  Priority:  minor      |   Milestone:
 Component:  Installer  |     Version:
Resolution:             |    Keywords:
Changes (by cnielsen):
  * summary:  Installer does not automatically select Grass dependencies =>
Comment:
 Trying again with 6.4.0RC2-2 adds several dependencies including gdal-16.
 However, several errors come up when starting grass, and it seems they
 relate to gdal. Starting grass in text mode, g.region -p gives error:
 "This application has failed to start because gdal16.dll was not found.
 Re-installing the application may fix this problem"
 The same error occurs with the test version 6.4.0RC3.
 The file gdal16.dll is not located anywhere within the OSGeo4W directory.
 Should I start a new ticket?
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/41#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev mailing list
