[osgeo4w-dev] [osgeo4w] #42: SDE Driver : MSVCP71D.dll (debug)
dependency
trac_osgeo4w at osgeo.org
Thu Jan 29 12:15:07 EST 2009
#42: SDE Driver : MSVCP71D.dll (debug) dependency
Reporter: mwtoews | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone:
Component: Package | Version:
Keywords: SDE |
While attempting to use gdal-sde92 (1.5.0-1) on a Win2003SP2 computer, I
get 2 errors: the first described in this ticket, and the second being an
(older?) issue from GDAL ticket 2552.
After installing gdal-sde92 (1.5.0-1) from OSGeo4W Curr, trying a command
like gdalinfo.exe shows a dialog (twice):
This application has failed to start because MSVCP71D.dll was not found.
and console output:
ERROR 1: Can't load requested DLL: c:\OSGeo4W\bin\gdalplugins\gdal_SDE.dll
126: The specified module could not be found.
This error is due to the build of gdal_SDE.dll with debugging enabled
(MSVCP71'''D'''.dll). This dependency should exist.
More info:
$ gdalinfo.exe --version
GDAL 1.5.4, released 2009/01/07
The second error is when ogrinfo is used on something normal, like
"ogrinfo myshapefile.shp":
$ ogrinfo myshapefile.shp
ERROR 4: SDE Driver doesn't support update.
Had to open data source read-only.
INFO: Open of `myshapefile.shp'
using driver `ESRI Shapefile' successful.
1: myshapefile (Point)
This error is likely related to http://trac.osgeo.org/gdal/ticket/2552
I do not know how to get the version info from OGR (-version or --version
or -v or -V flags do nothing).
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/42>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev
