[osgeo4w-dev] Re: [osgeo4w] #97: critical problems while editing
features
trac_osgeo4w at osgeo.org
Fri Jul 24 05:37:28 EDT 2009
#97: critical problems while editing features
Reporter: giohappy | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: critical | Component: Package
Version: 1.0 | Resolution: invalid
Keywords: QGis |
Changes (by giohappy):
* status: new => closed
* resolution: => invalid
Comment:
Ouch! Tha'ts awful! It's due to the snapping options!
If I simply open and close the snapping tab inside the Project Properties
the specific layer snapping options are set, otherwise the deafult global
options are used.
In my experience the expected behaviour is different:
- by default the global snapping options should be 0 (no snap)
- if I want gloabl snap I can set it's value in the the Digitizing tab
under Options
- if I want to set per layer options it should require to flag the
specific layer inside the Snapping Options window from Project Properties,
and set the snapping value.
Otherwise, before digitizing in lat-lon, I have to do the extra step to
change the dafult value (100) or open-close the Snapping Options window.
The latter is a very strange, unexpected, behaviour!
giovanni
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/97#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev
