[osgeo4w-dev] OWSLIB... what next
Matt Wilkie matt.wilkie at gov.yk.ca
Fri Jul 31 17:53:20 EDT 2009
Hi Dave,
You made two mistakes with setup.hint:
- was actually named setup.hint.txt
- and "requires:" was empty.
I renamed setup.hint properly and added "msvcrt" to requires (msvcrt is
guaranteed present as it's part of the minimal initial install). Now the
setup_test.ini has been updated. Carry on with testing :)
cheers,
matt wilkie
Geomatics Analyst
Information Management and Technology
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
Dave Sampson wrote:
> Hey Folks,
> Put together a package with setup.hint
> tared it
> bziped it
> created a new directory under release (owslib)
> Copied the tar.bz2 and .hint files over
> ran the CGI script from a web page
> Reloaded the setup program with th -t switch.
> Listed full list of packages and no glorry.
> Could someone look over it and let me know where I messed up?
> I feel close... it was relatively painless so far.
> Cheers
> osgeo4w-dev mailing list
> osgeo4w-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
More information about the osgeo4w-dev mailing list
