[osgeo4w-dev] [osgeo4w] #94: qgis-dev : missing gdal16.dll
dependency
trac_osgeo4w at osgeo.org
Sat Jun 27 15:28:29 EDT 2009
#94: qgis-dev : missing gdal16.dll dependency
Reporter: mwtoews | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Component: Package
Version: | Keywords:
After installing/updating qgis-dev via osgeo4w setup, on starting qgis-
dev, I see an error message:
This application has failed to start because gdal16.dll was not found.
Re-installing the application may fix this problem.
I have reproduced this message on a computer that updated qgis-dev, and on
another that installed osgeo4w for the first time. Re-running setup and
manually selecting the gdal16 package solved this dependency.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/94>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev
