[osgeo4w-dev] Re: [osgeo4w] #63: Qgis does not start - message:
component not found libssl32.dll
trac_osgeo4w at osgeo.org
Sun Mar 15 15:32:22 EDT 2009
#63: Qgis does not start - message: component not found libssl32.dll
Reporter: ema | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Component: Package
Version: | Resolution:
Keywords: qgis libssl32.dll |
Comment (by jef):
Replying to [comment:7 ema]:
> I tried to uninstall everything that concerns qgis and osgeo4w
> I cleaned the registry key
> I rebooted the pc
> and the result is always the same: I surrender! :-(
Looks like your problem isn't directly related to qgis or OSGeo4W at all.
I suspect that you have some DLL in your {{{%WINDIR%\system32}}} that
depends on {{{libssl32.dll}}}, which is picked up by some other DLL in
OSGeo4W instead of the intended DLL in OSGeo4W (we've previously seen such
things with {{{openssl}}}; see also #35 ff).
Please check the plugins with {{{depends}}}. You should find a plugin
that references {{{libssl32.dll}}}, but indirectly though another DLL on
your system.
Alternatively you could also search for a file contains {{{libssl32.dll}}}
using the Windows Explorer's search facility. That should also locate
that apparently broken DLL.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/63#comment:8>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev
