[osgeo4w-dev] Re: [Qgis-developer] cannot build qgis with python
inside osgeo4w: python isn't detected
Jürgen E. Fischer
jef at norbit.de
Mon Mar 30 07:32:37 EDT 2009
Hi Giovanni,
On Mon, 30. Mar 2009 at 12:22:18 +0200, G. Allegri wrote:
> Thanks Jurgen. But FindGRASS.cmake has this:
> FIND_LIBRARY(LIB_PATH grass_${LIB} PATHS ${G_PREFIX}/lib)
> so it looks for not-with-lib-prefix libs. Right? I can change it
> manually, but shouldn't it be changedas default too?
How did you name your grass libraries? If the are called grass_foo.lib
cmake should be fine - if libgrass_foo.lib probably not.
I usually specify them manually (or edit CMakeCache.txt from a previous
build).
> Do you mean that I should place all the needed manually to run PACKAGE
> target (and build the NSIS)?
No. If you want to build a NSIS installer, that's probably the easiest
way. Otherwise you just create an empty folder or remove the reference
to vcdeps at all.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
More information about the osgeo4w-dev
