[osgeo4w-dev] Re: [Qgis-developer] cannot build qgis with python
inside osgeo4w: python isn't detected
Jürgen E. Fischer
jef at norbit.de
Mon Mar 30 08:07:24 EDT 2009
Hi Giovanni,
On Mon, 30. Mar 2009 at 13:43:06 +0200, G. Allegri wrote:
> I left the grass build name them, and they result as libgrass_* . So I
> will change the cmake, but the FindGRASS one, as CMakeCache.txt
> doesn't contain such a variable (I only have grass_prefix and
> grass_include_dir)
Please don't. CMake follows convensions. It knows that libraries are
called name.lib for MSVC and libname.a for Unix (and MinGW). If you
change FindGRASS you break it for other platforms.
Rename you libraries instead.
> Anyway I have to solve another problem before: the sed script
My incarnation of that script is on http://buten.norbit.de/~jef/mklibs.
That also takes care of the lib renaming and removes the version tag
from the libraries.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
More information about the osgeo4w-dev
