[osgeo4w-dev] Re: [Qgis-developer] cannot build qgis with python
inside osgeo4w: python isn't detected
G. Allegri
giohappy at gmail.com
Mon Mar 30 10:10:16 EDT 2009
Now I receive a linking error, that says the grass_vect.lib is broken
as FATA ERROR 1127... What could cause this?
2009/3/30 G. Allegri <giohappy at gmail.com>:
>> Please don't. CMake follows convensions. It knows that libraries are
>> called name.lib for MSVC and libname.a for Unix (and MinGW). If you
>> change FindGRASS you break it for other platforms.
> Ok, I will.
>> My incarnation of that script is on http://buten.norbit.de/~jef/mklibs.
>> That also takes care of the lib renaming and removes the version tag
>> from the libraries.
> It seems to do the same as mine.
> I've made it work... it was an error of extra characters inserted by
> notepad. I had to remove them with an hex editor!
More information about the osgeo4w-dev
