[osgeo4w-dev] packaging: .tmpl files are deprecated, right?
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Feb 9 20:26:34 EST 2010
Matt Wilkie wrote:
> Hi Folks, I'm waking up and old thread here, 26/04/2008...
>> 2) Updated textreplace in msvcrt so that "-t abc.txt" will update abc.txt
>> in place if there is no abc.txt.tmpl file. As Jeff has pointed out it
>> is preferrable to update stuff in place rather than have template files
>> so that uninstall will cleanup better.
> I believe this means using .tmpl files should be deprecated as a
> standard packaging method? I'm happy to make the changes to
> http://trac.osgeo.org/osgeo4w/wiki/PackagingInstructions if this is the
> case.
Hi Matt,
I believe using .tmpl files (TextReplace Example #2) should be
deprecated, and this should be documented. Since textreplace can update
the actual file, there's no need for these tmpl file, in my opinion.
-jeff(m)
More information about the osgeo4w-dev
