Re: [osgeo4w-dev] georaster plugin
Ivan Lucena
ivan.lucena at pmldnet.com
Thu Jul 8 10:35:00 EDT 2010
Did you executed step #18?
Could you please try that sequence of commands:
C:\> gdal16
C:\> gdalinfo --version
C:\> gdalinfo --format georaster
C:\> ogrinfo --formats
It would be helpful if you could copy and paste the results on your next reply.
Thanks.
> -------Original Message-------
> From: Pasta Bolognese <pasta.bolognese at gmail.com>
> To: osgeo4w-dev at lists.osgeo.org
> Subject: [osgeo4w-dev] georaster plugin
> Sent: Jul 08 '10 04:19
> Hi All,
> I have installed the georaster plugin as explained in [LINK:
> http://www.oracle.com/technology/products/spatial/text/gdal_howto_compile_windows.txt]
> http://www.oracle.com/technology/products/spatial/text/gdal_howto_compile_windows.txt but
> for some reason the plugin is not there.
> C:\>gdalinfo --format georaster
> ERROR 1: --format option given with format 'georaster', but that
> format not
> recognised. Use the --formats option to get a list of available formats,
> and use the short code (ie. GTiff or HFA) as the format identifier.
> any ideas ?
> thanks
> osgeo4w-dev mailing list
> [LINK: compose.php?to=osgeo4w-dev at lists.osgeo.org]
> [LINK: http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev]
More information about the osgeo4w-dev
