[osgeo4w-dev] [osgeo4w] #172: sslmode error when adding PostGIS
layer
trac_osgeo4w at osgeo.org
Wed Jul 28 06:59:43 EDT 2010
#172: sslmode error when adding PostGIS layer
Reporter: morisimo | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: critical | Component: Package
Version: Alpha | Keywords: PostGIS, SSLmode
I am working on Windows XP SP2 and I am running 3 QGIS packages via the
OSGEO4W package manager, 1.0, 1.4 and 1.5.
I am trying to add a PostGIS layer from my PostGIS server where I need to
connect via SSL in "Require" mode.
I can connect to my database via the pgAdmin console, as well as via the
PostGIS Manager plugin.
However, when I try to add a PostGIS layer, I get the following error
message:
''"The database said: sslmode value "require" invalid when SSL support is
not compiled in"''
I do not get this error at all when adding a PostGIS layer in the
standalone install of QGIS 1.4.0.
Any help on this issue would be much appreciated!
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/172>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev
