[osgeo4w-dev] [osgeo4w] #158: textreplace memory error
trac_osgeo4w at osgeo.org
Tue Mar 9 18:05:25 EST 2010
Reporter: maphew | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Component: Installer
Version: | Keywords: apt
Installing [wiki:pkg-sip sip] with [wiki:pkg-apt apt] the computer appears
to hang during postinstall at the textreplace stage. Cpu usage is low,
around 12%, and python.exe memory use climbs slowly but inevitably until
it errors out tens of minutes later.
C:\>apt install sip
D:\o4w\cache/http%3a%2f%2fdownload.osgeo.org%2fosgeo4w/./release/python/sip/sip-
4.8.2-2.tar.bz2
76266867c6089ccea2e58edbba6db3b7 sip-4.8.2-2.tar.bz2 - remote
76266867c6089ccea2e58edbba6db3b7 sip-4.8.2-2.tar.bz2 - local
installing sip 4.8.2-2
C:\OSGeo4W>set OSGEO4W_ROOT=C:\\OSGeo4W
C:\OSGeo4W>textreplace -std -t apps\Python25\Lib\site-
packages\sipconfig.py
File "d:\code\o4w\apt\apt.py", line 1064, in <module>
__main__.__dict__[command] ()
File "d:\code\o4w\apt\apt.py", line 166, in install
do_install ()
File "d:\code\o4w\apt\apt.py", line 427, in do_install
post_install ()
File "d:\code\o4w\apt\apt.py", line 841, in post_install
lst.append(out)
MemoryError
I've encountered this once or twice before but didn't pause to document
it. I don't recall if it's always with the same package, or even always
textreplace (a vague recollection of dll-dupes). Running textreplace
manually on sipconfig.py.tmpl from o4w shell returns in seconds.
Host system is win7x64. Same results with apt from svn and package.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/158>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev
