[osgeo4w-dev] Re: [osgeo4w] #161: gdal utilities issues
trac_osgeo4w at osgeo.org
Tue Mar 16 16:41:46 EDT 2010
Reporter: lutra | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Component: Package
Version: | Resolution:
Keywords: gdal, gdal utilities |
Comment (by jef):
Replying to [comment:11 lutra]:
> Hi, I have run depends from the same shell where gdal16.bat was run. The
result is the same. See attached file.
Ah ok, you're not running from the OSGeo4W shell. If you use the
"standard" command
prompt you need to run {{{o4w_env.bat}}} to setup the environment for
OSGeo4W. Without it {{{%OSGEO4W_ROOT%}}} is unset and {{{gdal16.bat}}}
won't set proper paths.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/161#comment:12>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev
