[osgeo4w-dev] Re: [osgeo4w] #161: gdal utilities issues
OSGeo4W trac_osgeo4w at osgeo.org
Wed Mar 17 19:03:13 EDT 2010
Reporter:  lutra                 |        Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  defect                |       Status:  new
Priority:  major                 |    Component:  Package
 Version:                        |   Resolution:
Keywords:  gdal, gdal utilities  |
Comment (by brushtyler):
 Replying to [comment:19 jef]:
 > Replying to [comment:17 brushtyler]:
 > > But how can I import the gdal16 lib in python?
 > You're not supposed to. You run python from a OSGeo4W shell after
 running {{{gdal16.bat}}} or prepare a batchfile you can run anywhere (like
 {{{%OSGEO4W_ROOT%\bin\qgis-dev.bat}}}).
 No, I meant import gdal16 in python plugins into qgis.
 [[BR]]
 In this moment I run qgis-dev.bat then the gdal16.bat was yet called. But
 gdaltools-plugin fails to import gdal16-python tools by calling "import
 gdal", because it tried to import the inexistent gdal lib!
 [[BR]]
 About gdal in qgis, in linux gdal1.6 *overwrite* gdal1.5, then why the
 osgeo4w on win doesn't have the same behaviour? [[BR]] If I install gdal16
 lib, I suppose and want (if supported) it will be used!
 I think this is an osgeo4w issue, do you?
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/161#comment:21>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev mailing list
