[osgeo4w-dev] Re: [osgeo4w] #161: gdal utilities issues
OSGeo4W trac_osgeo4w at osgeo.org
Thu Mar 18 09:02:11 EDT 2010
Reporter:  lutra                 |        Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  defect                |       Status:  new
Priority:  major                 |    Component:  Package
 Version:                        |   Resolution:
Keywords:  gdal, gdal utilities  |
Comment (by lutra):
 > Probably.  But if that is only happening on Windows 7/Vista, we must be
 missing something special there, but generally it should work - and
 unfortunately also works here with Win7 64Bit.
 Hi Jurgen,
 until now I haven't find a single Vista/Seven machine where the osgeo4w
 gdal .exe utilities do work without crashing. In all the pc where I
 installed osgeo4w were typical user machines, nothing special installed
 related to development & co. This should be have some meaning... that -I
 guess- in general the osgeo4w gdal utilities doesn't work (under
 Vista/Seven).
 It should be easy during the hackfest make the necessary comparison from
 your machine and another Vista/Seven installation. I'll miss the hackfest
 but I'm sure Giuseppe can have a look to it with you.
 Cheers
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/161#comment:23>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev mailing list
