[osgeo4w-dev] [osgeo4w] #163: Unable to load PROJ.4 library
OSGeo4W trac_osgeo4w at osgeo.org
Wed Mar 24 09:37:38 EDT 2010
Reporter:  timmie  |       Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  defect  |      Status:  new
Priority:  major   |   Component:  Documentation
 Version:          |    Keywords:
 Using ogr2org from OSGEO4W directly, I got the following error:
 ERROR 6: Unable to load PROJ.4 library (proj.dll), creation of
 OGRCoordinateTransformation failed.
 Warning 1: Failed to create coordinate transformation between the
 input coordinate system and WGS84.  This may be because they
 are not transformable, or because projection services
 (PROJ.4 DLL/.so) could not be loaded.
 KML geometries may not render correctly.
 This message will not be issued any more.
 Source:
 GEOGCS["WGS 84",
     DATUM["WGS_1984",
         SPHEROID["WGS 84",6378137,298.257223563,
             AUTHORITY["EPSG","7030"]],
         TOWGS84[0,0,0,0,0,0,0],
         AUTHORITY["EPSG","6326"]],
     PRIMEM["Greenwich",0,
         AUTHORITY["EPSG","8901"]],
     UNIT["degree",0.0174532925199433,
         AUTHORITY["EPSG","9108"]],
     AUTHORITY["EPSG","4326"]]
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/163>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev mailing list
