[osgeo4w-dev] Re: [osgeo4w] #222: Making GDAL Java bindings work
trac_osgeo4w at osgeo.org
Tue Apr 26 03:13:53 EDT 2011
Reporter: Marvin | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Keywords: Java GDAL UnsatisfiedLinkError compatibility
Comment(by moovida):
Hmm, the reason we have an older gdal binding in the java package, is
because uDig and geoserver (at least these are the ones I know of)
bindings require those older bindings and would not work with an updated
version.
right now the only solution is to upload a customized java virtual machine
to be used with the project that needs it.
We are in the process to start to migrate to the new binding versions of
gdal-java, but I can't say right now when that will be.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/222#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev
