[osgeo4w-dev] Re: [osgeo4w] #245: gpsbabel fails to open some files
OSGeo4W trac_osgeo4w at osgeo.org
Mon Dec 5 17:52:33 EST 2011
Reporter:  Alister  |       Owner:  osgeo4w-dev@…
    Type:  defect   |      Status:  new
Priority:  minor    |   Component:  Package
 Version:           |    Keywords:  gpsbabel
Comment(by maphew):
 Ah, that helps. I can confirm the error on my system now. It turns out
 that if the `gdal-filegdb` package is installed ogrinfo never tries to use
 the gpsbabel format:
 >ogrinfo problem.gdb
 ERROR 1: Error: Failed to open Geodatabase (The system cannot find the
 path specified.)
 path specified.)
 FAILURE:
 Unable to open datasource `problem.gdb' with the following drivers.
   -> FileGDB
   -> ESRI Shapefile
 What does the working `gpsbabel -V` report on your system? (osgeo4w is
 1.4.2)
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/245#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
