[osgeo4w-dev] pkg-apache: setting path
Jürgen E. Fischer
jef at norbit.de
Sun Feb 20 18:22:04 EST 2011
Hi there,
I'm still trying to package QGIS-Mapserver. I'd like to simply ship it with a
httpd_qgis.conf for %OSGEO4W_ROOT%\httpd.d with that would have the necessary
configuration.
That would include adding add some directories to PATH to enable loading of
everything qgis_mapserv.fcgi.exe needs.
But SetEnv PATH doesn't seem to work. Only adding directory to the system's
path and rebooting the machine seems to have effect.
A simple php script like
<pre>
<?php
echo "PATH: " . getenv("PATH") . "\n";
echo "REDIRECT_PATH: " . getenv("REDIRECT_PATH") . "\n";
echo "GDAL_DATA: " . getenv("GDAL_DATA") . "\n";
</pre
produces:
PATH: C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\system32\WBEM
REDIRECT_PATH: C:\OSGeo4W\bin
GDAL_DATA: C:\OSGeo4W\share\gdal
So apparently SetEnv on GDAL_DATA worked fine, while SetEnv PATH
only modified REDIRECT_PATH and left PATH as it was - which doesn't help.
I originally thought Apache 2.2.17 would cure this, but 2.2.17 from MS4W also
has this problem.
AFAICS I now only have two options:
1. modify the system wide PATH and reboot on install or
2. copy all potentially necessary DLLs to the same directory as
qgis_mapserv.fcgi.exe.
Both options not really nice. Are there another options?
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
More information about the osgeo4w-dev
