[osgeo4w-dev] Re: [osgeo4w] #199: multiple GDAL versions used
OSGeo4W trac_osgeo4w at osgeo.org
Sun Jan 30 05:26:36 EST 2011
Reporter:  msieczka  |        Owner:  osgeo4w-dev@…
    Type:  defect    |       Status:  closed
Priority:  trivial   |    Component:  Package
 Version:            |   Resolution:  wontfix
Keywords:            |
Changes (by jef):
  * priority:  major => trivial
  * status:  reopened => closed
  * resolution:  => wontfix
Comment:
 Replying to [comment:2 msieczka]:
 > Replying to [comment:1 jef]:
 > > The output in the about box is wrong.  QGIS is using GDAL 1.7.
 > Can the dialog be fixed then? On my Linux installations, and the OSGeo4W
 1.7.0 one, the build-time and run-time GDAL versions match. Only the
 OSGeo4W 1.6.0 install claims it was built against 1.5, while running
 against 1.7.
 This is kind of a non-issue.  Everything works fine and it's using GDAL
 1.7.  I won't rebuild QGIS 1.6 just to get the about box right.   This
 will solve itself with the next release.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/199#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev mailing list
