[osgeo4w-dev] gdal-python for py2.7 is broken
Jürgen E. Fischer jef at norbit.de
Fri Jun 3 17:58:50 EDT 2011
Hi Matt,
On Wed, 25. May 2011 at 17:03:41 -0700, Matt Wilkie wrote:
> If I move the contents up to ../site-packages then the scripts work. I
> assume this means the .egg directory structure is an oversite, or were
> you meaning to move to using easy_install to complete the install?
Sorry for the late response.  I just updated all affected packages.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
More information about the osgeo4w-dev mailing list
