[osgeo4w-dev] Re: [osgeo4w] #117: Dependencies are not tracking
on Windows Server 2003 x64
Matt Wilkie
matt.wilkie at gov.yk.ca
Wed Mar 2 10:37:37 EST 2011
> Is there a work-around for this? Is there perhaps another way to install
> osgeo4w? Or nightly snapshot binaries for common configurations?
You could try the apt command line installer.
(http://trac.osgeo.org/osgeo4w/wiki/pkg-apt) It seems to work for me on
Windows 2003 x64:
D:\temp>set osgeo4w_root=d:\o4w
D:\temp>python apt.py setup
Root dir not found, creating d:/o4w
creating d:/o4w/etc/setup/
creating d:/o4w/etc/setup//installed.db
getting d:/o4w/etc/setup//setup.ini
...100%
D:\temp>python apt.py install qgis-dev
to install:
fftw libtiff libjpeg12 python-win32 fcgi wxpython netcdf curl msvcrt
iconv sip xerces-c libpq geos proj libmysql sqlite3 tcltk libgeotiff
expat pyopengl gsl -libs python gdal17 python-numpy qt4-libs pyqt4
libpng qwt5-libs-qt4 qgis-dev ms ys gdal avce00 xerces-c-vc9 ogdi
freetype-mingw hdf4 hdf5 libjpeg proj-datumgrid zlib proj-hpgn gdal15dll
pdcurses gpsbabel openssl grass gdal-python
cheers,
-matt
More information about the osgeo4w-dev
