[osgeo4w-dev] 64 bit installs
andrea antonello
andrea.antonello at gmail.com
Thu Mar 10 14:50:42 EST 2011
Hi, I was wondering if there are packages that supply also a 64bit version.
For uDig for example it would make sense, because the 64bit virtual
machine can use more RAM than the 32bit (only about 1gig). On the
other hand some of the rastering libraries are not supported, so it
would be limited on that side. So really a user should be able to
choose based on a description.
I assume there is no clean way to present such a schenario right now?
Thought I would ask,
Thanks,
Andrea
More information about the osgeo4w-dev
