[osgeo4w-dev] Download from mirror?
Matt Wilkie matt.wilkie at gov.yk.ca
Tue Mar 29 17:26:10 EDT 2011
There is an .exe which doesn't require dependencies that can be grabbed
from http://code.google.com/p/maphew/wiki/OsgeoFromScratch. It lags
behind the svn version a bit, the most notable lack at the moment being
that it can't read certain bz2 files
(http://trac.osgeo.org/osgeo4w/ticket/209).
((reads next messsage))
Oh I see you already found the from scratch recipe ;-)
sending this on anyway to note the bzip2 flaw. I'll try and scrape some
time together to generate a new .exe soon.
matt wilkie
Geomatics Analyst
Information Management and Technology
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
On 29/03/2011 1:25 PM, andrea antonello wrote:
> Hi Matt,
> I was really hoping for this to work without dependencies. It needs
> python though, which I had installed, but not in my osgeo4w install.
> So even if the apt install via commandline is easy and works (tested,
> yeah!), one has to go through a customized install of python, which
> kind of defeats the purpose. Anyways I am sure many will be happy to
> install also by doing so and most probably many will have python
> installed, so I will wrap the instructions up and let others know.
> Thank you for the help!
> Andrea
More information about the osgeo4w-dev mailing list
