[osgeo4w-dev] shpproj (and others) can't find proj_fw.dll
Jürgen E. Fischer jef at norbit.de
Mon May 23 16:53:21 EDT 2011
Hi Charles,
On Mon, 23. May 2011 at 15:05:53 -0400, Charles Karney wrote:
> Starting up the OSGeo4w shell via the start menu opens a CMD window
> which reports OSGEO4W home is C:\OSGeo4W.  Then I get an alert saying
> that gdalinfo was unable to locate proj_fw.dll and suggestiong that I
> reinstall the application.  If I dismiss the warning and run shpproj I
> get a similar warning about proj_fw.dll.
I can't reproduce the problem with gdalinfo, but I can confirm that shapelib
has a bug[1].
Jürgen
[1] http://trac.osgeo.org/osgeo4w/ticket/229
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
More information about the osgeo4w-dev mailing list
