[osgeo4w-dev] [osgeo4w] #289: apt intolerant of filename missing
package version number
trac_osgeo4w at osgeo.org
Fri Apr 27 12:58:47 EDT 2012
#289: apt intolerant of filename missing package version number
Reporter: maphew | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Keywords: pkg-apt
The recent gdal-filegdb release, #279, reveals apt is pickier than
setup.exe when it comes to parsing the version number from the package
filename.
B:\> python b:\code\o4w\apt\apt.py new
The following packages are newer than the installed version:
*** Error parsing version numer from "gdal-filegdb-1.9.tar.bz2"
File "b:\code\o4w\apt\apt.py", line 1113, in <module>
__main__.__dict__[command] ()
File "b:\code\o4w\apt\apt.py", line 256, in new
for packagename in sorted (get_new ()):
File "b:\code\o4w\apt\apt.py", line 632, in get_new
new = get_version ()
File "b:\code\o4w\apt\apt.py", line 684, in get_version
package['ver'] = split_ball (ball)[1]
File "b:\code\o4w\apt\apt.py", line 803, in split_ball
return (m.group (1), string_to_version (m.group (2)))
AttributeError: 'NoneType' object has no attribute 'group'
By spec, the filename is to have program version number followed by a
package version number; see PackagingInstructions,
[[Image(http://trac.osgeo.org/osgeo4w/raw-
attachment/wiki/PackagingInstructions/package-name.png)]]
Setup is quite happy to continue without a package version though, so we
should follow suit. I looked through Setup source files
(package_version.h, .cc) and I ''think'' it just assumes a version of 0 if
pkg-num missing, e.g. gdal-filegdb-1.9'''-0.0'''.tar.bz2 from gdal-
filegdb-1.9.tar.bz2.
In apt this would be handled in the (mis-named) `def split_ball()` parser.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/289>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
