[osgeo4w-dev] Re: [osgeo4w] #289: apt intolerant of filename
missing package version number
trac_osgeo4w at osgeo.org
Fri Apr 27 14:52:13 EDT 2012
#289: apt intolerant of filename missing package version number
Reporter: maphew | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Keywords: pkg-apt gdal-filegdb
Comment(by maphew):
Thanks for updating the archive name so existing apt installs can carry
on.
It might wise to be stricter on package name convention. Setup.exe is just
fine now without the p-ver#, but what would happen with a new version? It
might force updating setup.hint manually instead of relying on the
automatic "what is current and new" algorithm.
I took the opportunity to understand and document the regex filename-to-
version matching, checked in at r1189. I didn't get as far as attempting
to add "assume no p-ver# means ver# 0". The parsing is spread across 3 or
4 functions and it really should be in one, with names that mean
something. I'm not up to that yet ;-)
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/289#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
